What kind of performance from a T56 can I expect?
Old Jun 6, 2010 | 06:17 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Just wondering what kind of performance I can expect from swapping out a 700R4 with 200'000 kms to a T56 6 speed? It's going in a 5.7L GTA. Is it a real kick in the pants? Will it let the car really pond pavement or is it going to be more or less the same.?
Old Jun 6, 2010 | 10:04 PM
fleetmgr's Avatar
Re: What kind of performance from a T56 can I expect?
Without a corresponding change to the rear end gear ratio, you probably won't like it much.
Old Jun 6, 2010 | 10:14 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
It seems like a lot of the 4th gen guys like 4.11's with their t-56's. The double overdrive lets you run a steep gear in the back without hurting your cruise rpm's.
Old Jun 7, 2010 | 12:12 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
If you like driving stick it's nice but you will probably get no performance gain, also stick with 3.7 gear ratio for a TPI car, I found 4.10's little much.
If your looking for little more pep maybe a stall converter is what you need.
Old Jun 9, 2010 | 08:53 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thats not what I was expecting. I went for a ride the other day in a 5 speed 4.6L Mustang and could not believe the pull and power especially on the 3rd gear downshifts. I really miss that feeling from the Auto. I figured a 5.7L mated to an auto would be a blast, and at least as fun as the 4.6L Mustang
Old Jun 9, 2010 | 01:50 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Oh trust me the fact that it's a manual will give it a hell of a kick. The solid connection between teh engine and the rear wheels makes an amazing difference in the feel of the acceleration and the attitude of the car.
But dont expect the car to get better times unless you have decent gearing. It's worth it for the fun factor, but if you're only trying to get your ET's down, there are better options and you'll be disappointed.
http://www.youtube.com/watch?v=0R-QlGlKGV0
Mine... So much fun...
Old Jun 9, 2010 | 02:22 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
I have a 305 with a 5speed. Gear ratio is at 3.42. Any deference if i mate my 305 with a t56?
Old Jun 9, 2010 | 02:32 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I dont plan on racing it at the strip. I just want it for playing around. I'd love to be able to play spank a few mustangs for fun Lol we all know each other but Im the only GM guy in the group
Old Jun 9, 2010 | 03:20 PM
Car: 1992 Camaro RS
T56's will like gears a step shorter than T5's. The T56 has a taller first gear and a super tall final gear, so basically 3.73s-4.10s are perfect for them. 3.42's will be tolerable, though. My 3.27's are way too tall for it and it makes the car a bit less fun than it should be.
Hotrodboba400
Dec 10, 2019 07:07 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
