estimate hp/tq.
Old Jun 10, 2010 | 07:29 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
estimate hp/tq.
well guys i had bought a 350 motor that was a 4 bolt main, bored .030, and somewhat fresh rebuild and a th350 tranny all for $150.
Got it installed, had new 2.5 inch exchaust put on it and got it inspected. ran great and was snappy. had a vibration while I drove it down the road at like 35 but if you put the car in neutral it went away.
Now here is the but. Everyday I drove it, it seemed to loose more and more power. then after a burn out, I mean right after the burn out it idle rough. and when you drove down the road with the throttle in at a consistant pace the car was like in and out. Found that cyclinders 2 and 8 were dead i pulled #4 and the car shut off and couldnt start it back up because the appendix on the starter broke. did not do a compression check. instead i took the whole motor apart everything seemed to be normal were and tear. main bearings had some grooves and they had like a brownish color to them. Oh and the motor was not bored at all. What do you guys think happened.
Which brings me to my next topic. If any here could give me an estimate on my hp/tq on my new build up.
383 stroker with flat top pistion.
64cc heads, stage 1 ported, and valve size undiced at this point either 194/150 but most likely will be 202/160 if you can give me numbers for both that would be great.
cam: hi rev from 2800-6000 int/exh both 436 and lift both 436
going with and edlebrock dual plane air gap intake
750 cfm carb. havent decicded wether to go with edlebrok or holley
also undiced on rocker ratio i know if i go with 1.6 i will get more lift but have now idea what it will do power wise as i'm still new to this and learning as i go. I have a friend that is helping me out on this.
Do you guys know what the stock gear ratio is in a 84 firebird.
Finale question is the th350 i need to get beefed up talked to a local guy about rebuilding it and putting in a shift kit. he wants 1025. Or should i just get a trans from summit for 900 that comes with a torque converter.
sorry for the long read and thanks for any input/suggestions.
Old Jun 10, 2010 | 08:17 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: estimate hp/tq.
Nothing about your proposed build looks right to me. Well, the 383 part is good. 11:1? NO. 436/436 cam? NO. TH350? NO. Mystery gearing? NO.
read the first 7 posts of this thread: https://www.thirdgen.org/forums/engi...st-builds.html
I'd bet all 6 of the 383 combos mentioned therein are making more than you hoped to, and only one of them is over 9.5:1 there are full details and real dyno details on 4 of them
Old Jun 10, 2010 | 08:32 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: estimate hp/tq.
Don't forget mystery heads.
Old Jun 10, 2010 | 08:39 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: estimate hp/tq.
good catch!
Old Jun 10, 2010 | 05:22 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: estimate hp/tq.
opps the cam is 224 and the lift is 436
Old Jun 10, 2010 | 09:46 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: estimate hp/tq.
Anyone else. I already got the kit and it came with the cam.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
