Help no O2 Data
Old Jun 13, 2010 | 09:14 PM
55tpichevy's Avatar
Car: 55 chevy,2000 corvette
Engine: 1990TPI and LS1
Transmission: TH350 W/gear vendor and 6 speed man
Axle/Gears: 85 corvette 3.07 and 2000 vette3.07
Help no O2 Data
I've got a 1990 355 tpi with 730 ECM while running Datamaster I get all data except O2 voltage (stays at 450 mlv),and the BLM never changes (128). I had a 4 wire O2 (GM) installed in my headers. So I replaced it with a AC Delco 3 wire and still no data. Checked connection from O2 to the ECM is good. ON the ALDL web site it shows data going to two pins on the ALDL connector under the dash,(pin m and e). I have pin M connected. I'm I missing something? My wideband is working fine, is there a way to control the ECM with the wideband? I'd rather get the ECM to use the OEM NB O2. anybody have an idea what the problem is ? any help please thank you Mike
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
