anybody know why my car is dieing
Car: 85 camaro
Engine: sbc 400 .30 over
Transmission: 700r4 with bm shift kit, 2200 stall
Axle/Gears: 7.625 10 bolt posi
a have a 305 non computerized engine it first started out with my trani siezing up, i changed it out and it helped but now i still have a problem i dont know what it is but when you start it it trys to die unless you hold the throttle for a min then it stays at idle but it jumps up and down a little bit but when you throw it in gear it dies, ecspecialy in reverse but once you get going its fine, other than the slite hesitation under 1500 rpms. now i checked the spark its fine, i checked the fuel, its getting to the carb and in to the intake and i checked all the vaccume lines, there good. any ideas?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: anybody know why my car is dieing
db057
Aug 11, 2015 10:11 PM
