engine problems
Old Jun 18, 2010 | 12:54 AM
Gabe10's Avatar
Car: 91 RS
Engine: 3.1l
engine problems
Please help me. On Monday I changed all my ignition components and vacuum lines. I went to work the next day ran fine going but on the return trip my car would not rev when passing, instead it bogged down and almost died several times. Anyways about an hour after I got home and let the car rest it would not run, the idle speed was very low (400 rpms) and rough. also if I tried to press the gas the engine would die. What could be the problem?
Old Jun 18, 2010 | 02:19 AM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Re: engine problems
Is the check engine light on?
Old Jun 18, 2010 | 03:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: engine problems
Dittot he previous poster. Also it sounds like something came loose since it was running fine. Double check all your connections and make sure the distributor is tight.
Old Jun 18, 2010 | 07:53 PM
Gabe10's Avatar
Car: 91 RS
Engine: 3.1l
Re: engine problems
My chesk engine light is not on and I made sure all connections are nice and tight. I even tried different sensors. TPS, MAP, and the IAC valve
Old Jun 25, 2010 | 09:28 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Re: engine problems
im having the same problem and so are several others. its a ghost problem man!
Old Jul 8, 2010 | 10:14 PM
Gabe10's Avatar
Car: 91 RS
Engine: 3.1l
Re: engine problems
I figured out the problem if you are expeirinecing this problem check your fuel injectors 4/6 of mine were off the specified ohms limits.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
