What would happen if you just ploped in a carb and a not electric dizzy?
Old Jun 18, 2010 | 02:07 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Say you got a regular 305 tbi. If you just get a carb and manifold to match, pop it in, and drop in a non-electric dizzy, what would happen?
Is there any other part of the engine that the ECM controls? If not, would the ECM freak out and make other things not work correctly?
Thanks for any info.
Old Jun 18, 2010 | 04:26 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: What would happen if you just ploped in a carb and a not electric dizzy?
Should work just fine... You'd also need to do something about the fuel pressure, it'll be too high for a carb. Either use a Mallory 4309 style regulator or unplug the pump and get a cheap $40-$60 mechanical...
Old Jun 18, 2010 | 05:46 PM
one92rs's Avatar
Car: SOLD!!!!!
look in the carb section. i did mine. there is plenty of info in there on it. also i left my ecm in and im using it as a powerslave.
Old Jun 18, 2010 | 06:14 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Does anyone know if the computer will still retain use of the knock sensor circuit if it's unplugged from most of the other sensors? (keeping the dizzy reference pulse, so it knows the engine is alive). I think that would be a far cheaper choice than buying a stand alone knock sensor module for those running some of the more radical compression values.
But, to answer your question, yes it will run with just carb and distributor, and fuel system changes (as previous posters pointed out) If you know your wiring, you might even be able to keep cruise control. If you have electric fans, get a fan switch to replace the computer controlled fan (or wire the computer up to piggy back things like fan switch, 1990+ speedometers, 1990+ cruise control modules) Your EGR, AIR, and EVAP will no longer work, so make provisions for those that need it (vent your tank, etc)
Old Jun 18, 2010 | 06:40 PM
one92rs's Avatar
Car: SOLD!!!!!
no you lose cruise control and the knock sensor. the check engine light will stay lit. all ecm control will be lost on timing. you need to go to the carb section and start reading about this swap.
junkcltr
Aug 2, 2019 11:12 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
