113 heads on 305
Car: 88 Camaro
Engine: 305 TBI
113 heads on 305
I wan't the 113 heads for my 91fbd w/ 305 tbi for weight reduction purposes, but I know you lose compression too. They come with 58cc combustion chambers but I hear 54cc will bring it back to stock compression. How much needs to be milled off these heads to maintain stock compression?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 113 heads on 305
I know these heads are a 'perfect' match for 305 "TPI" (LB9) engines, which also had 58cc chambers. They are about 50lbs lighter than the stock iron heads, and flow better than the stock ones. I don't know about TBI though!
Car: 88 Camaro
Engine: 305 TBI
thanks for the quick reply, wasnt aware of this..well my other choice is the 059 vortec head (they have the same combustion chamber size as what I currently have)..could i just get those shaved so I have a few less cc's of chamber and a higher cr to where I can run 93 octane and make a little more power? what would be a good chamber size for this? Thanks
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
059 Vortecs use the same intake port/bolt pattern as the L31 Vortecs - your stock intake won't work. They also don't have the good chamber design that the L31 is so popular for. The 113 Corvette heads would be a better choice IMO - use the stock intake, and they are a slightly better head too.
Just to give you a heads up, there's a ton of info on these heads on this thread, in case you missed it:
https://www.thirdgen.org/forums/tech...questions.html
Lots of debate and info on these heads...
Car: 88 Camaro
Engine: 305 TBI
Yeah I read it, but I cant find any threads with any real numbers. All i really want to know is which one makes more power, and where at in the power band, and also how much these two different heads can be milled for best possible compression on pump gas
Transmission: 4L80E/4L80E
Rather than fooling around with factory castings, why not just get something ready to bolt on? http://www.summitracing.com/parts/TFS-30300001/
Perimeter valve cover bolt pattern, and '86-earlier intake bolt pattern, but they would be better than either 113's or 059's.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
This is the centerbolt 87 up version http://www.summitracing.com/parts/TFS-30300005/
ambainb
Apr 25, 2016 09:21 PM
