150 psi of compression good?idles high and not fireing on 3 cylinders!!!!
Old Jun 21, 2010 | 03:11 PM
my84camaro's Avatar
150psi of compression on all cylinders.was a 305 motor swapped in a 350 and used the stock 305 roller cam setup,heads,intake and tb.added headers and h-pipe to match with no cat.idles at 1500k and wont go any lower.misfires on cylinder 4,7 and 8..has plenty of power but can tell it miss fires when hitting the gas hard and at idle the air going into the tb is loud.sounds like a vacuume line disconected but there isnt...
anyone have any ideas for me?
Old Jun 21, 2010 | 05:29 PM
my84camaro's Avatar
Re: 150 psi of compression good?idles high and not fireing on 3 cylinders!!!!
read codes and they are tps voltage low and coolant sensor low.them have any thing to do with it?
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
BBSDesigns
Aug 11, 2015 07:39 PM
