block is .60 over head gasket is stock
Old Jun 23, 2010 | 02:15 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I have a 350 bored .60 over and im using 113 heads with stock head gaskets that came in the felpro engine rebuild kit,my questions is will a stock gasket even work for this application can i modify it if it needs to match the bore or do i get a new one.
Old Jun 23, 2010 | 02:25 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: block is .60 over head gasket is stock
It should be fine. Most gaskets included with rebuild kits will accomidate common rebuild bore sizes.
Old Jun 24, 2010 | 01:04 PM
C305's Avatar
Car: 91 camaro vert
Yea thats what i was thinking because the heads never changes so aslong as its matchd to that it should seal no matter what the bore on the block is,thanks for the help
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
