Crate engine info
Old Jun 24, 2010 | 11:53 AM
Skyshadow's Avatar
Car: 89 Trans AM GTA
Engine: 5.7 V8 TPI
Crate engine info
I'm currently looking at a 1983 trans am which had an engine and transmission swap.
The engine is a 1979 350ci GMC Jimmy crate engine (15000 miles). with a 5 speed T5 world class transmission. Im wondering how good of an engine this is cause im really interested in this car as I will save me a lot of money to get one with a 5speed installed. I'm just questioning the engine cause I don't know anything about crate engines at all. If anyone has experience with these engines please help me out.
Old Jun 24, 2010 | 12:06 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Crate engine info
It is probably nothing special, just a generic 350 replacement engine.
Old Jun 24, 2010 | 12:35 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the term "Crate Engine" is very over used/mis-used . to me a crate engine is one from G.M. , summit , edelbrock etc. . ones from advance , auto zone and so on are just generic replacement engines . while they may be o.k. nothing special . do you have anymore info. ? good luck .
Old Jun 24, 2010 | 01:36 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
It's probably a low compression engine with junky heads. I wouldn't pay extra cause it's a "crate engine."
That said, a third gen is not a heavy car and even a crappy small block will scoot it along nicely. With a 3.42 rear my LO3 305 gets up and goes.
Old Jun 24, 2010 | 03:46 PM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
The casting numbers are on the block back where it bolts to the trans. Get them and google them. You will be able to see if its really a Goodwrench crate or just a rebuilt motor from Autozone or something..
They will also tell you if its 2 or 4bolt main.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
