intake manifold's??? help
Old Jun 24, 2010 | 07:03 PM
lwold08's Avatar
hey which intake is better squarebore or spreadbore and carb size for an engine that is bored .60 over and sleeved at .40, bigger cam, etc etc etc maybe 450 horse's pushin, thanks
Old Jun 24, 2010 | 07:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Carb size - general rule of thumb is CID x max RPMS / 3456. You need at least that much carb. A little larger if you're using a dual plane intake.
Intake type - if know you'll be using a squarebore carb, get a squarebore intake. If you'll be using a spreadbore carb, or might be, get a spreadbore intake.
Obviously, the information you provided isn't enough to get more specific. What you'll be doing for cam & heads is also important, as is what you plan on doing with the car when you put that engine in it.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
