FUEL PUMP BAD?
Old Jun 26, 2010 | 04:18 PM
Z28GARAGE's Avatar
FUEL PUMP BAD?
How can I check to see if my fuel pump is working. Car turns over but will not start. Check engine light is also on car has been sitting a long time.
Old Jun 26, 2010 | 04:36 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: FUEL PUMP BAD?
check fuel pressure and make sure the pump is getting power.
Old Jun 26, 2010 | 09:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: FUEL PUMP BAD?
What year? What induction? What motor?
Old Jun 28, 2010 | 10:04 PM
Z28GARAGE's Avatar
Re: FUEL PUMP BAD?
87 iroc, 305 tpi
Old Jun 29, 2010 | 06:49 AM
Car: 1992 RS
Engine: Carbed 350
Re: FUEL PUMP BAD?
Have someone turn the key to on while you are under rear with ear against tank - you should hear the pump "prime" for about 2 seconds. If it does not, then I'd look into the fuel pump relay, try changing it out.
You can display the SES error codes by following this:
https://www.thirdgen.org/service-eng...ht-error-codes
Old Jun 29, 2010 | 10:55 AM
Car: 90 formula
Transmission: auto
Re: FUEL PUMP BAD?
id even have them prime but they weren't up the to the pressure it should have been. just get a fuel pressure gauge and go from there.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
