Ignition won't turn. Any ideas?
Old Jun 26, 2010 | 08:51 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
My ignition seems to be stuck. My key won't turn it. It's locked somehow and won't turn. I have no idea how to fix it. Any ideas?
Old Jun 26, 2010 | 09:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Ignition won't turn. Any ideas?
Are you all the way in park?
Old Jun 26, 2010 | 09:10 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
This happended to me. It was my ignition switch. Not the cylinder where the keys go, but the switch located halfway down the steering column.
Besides checking to make sure your in park, have you tried turning the steering wheel a little both ways while turning the key?
Old Jun 26, 2010 | 09:34 PM
Car: '84 Trans Am
Engine: 350 Carb
It's all the way in park. My shifter is locked in park, my steering wheel is locked, and the key won't turn. What's sad is I just got it back from the mechanic doing the engine swap. I drove it back to my house, cleaned the interior, then bam can't turn the key. WTF. All I wanna do is drive it finally and I can't.
Old Jun 26, 2010 | 09:41 PM
built91Z28's Avatar
If the wheel is locked then try turning the wheel a little. It wont move much but there may just be too much pressure on the locking mechanisim and turning the wheel a little could take the pressure off.
Old Jun 27, 2010 | 02:44 PM
Car: '84 Trans Am
Engine: 350 Carb
I've been trying that for the last hour and nothing. Still won't turn. I can turn it backwards but not forward. I'm almost to the point where I'm gonna get channel locks and force it. I figure if I'm gonna have to tear into the steering column I might as well break something.
Old Jun 27, 2010 | 03:56 PM
Car: '84 Trans Am
Engine: 350 Carb
Wow. I man handled it with channel locks, heard a snap, and now it works.
Derick15
Sep 17, 2016 05:28 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
BrianI
Aug 9, 2015 11:52 AM
