morse code
morse code
could someone help me figure out what my computer codes are? i have 1 flash, pause and 5 more quick ones and then 2 flashes, pause and 2 quick ones. ive read a many post on here and just havent it decoded the problem.
Car: 1986 Iroc z
Engine: 350 tpi
Re: morse code
are you usinng a code reader? If so. the first 3 sets of codes should be code 12. thats flash, flash flash pause flash, flash flash that would be code 12 it should do that 3 times. that means the computer is reading ok. after that count the flashes again. flash flash pause flash flash flash pause. that would be code 23. once you get all the codes then i can tell u what each one means.
