what is this?(pic) and where to bolt engine to stand
Old Jun 27, 2010 | 03:12 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
hey guys
so i got things here 1) what is this lil unit on the side of the plenum? just some EGR stuff? (putting in a HSR)
2) where should i bolt my new block to a engine stand? the only bolt holes there seem a lil small but i could be mistaken. THANKS
Old Jun 27, 2010 | 04:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: what is this?(pic) and where to bolt engine to stand
That is the MAP sensor. You can just bolt the engine to the stand using the bolt holes from the bellhousing.
Old Jun 27, 2010 | 04:03 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
and what does it do? how do i rig that up on a stealth ram or does it get left out?
Old Jun 27, 2010 | 04:08 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
just hook it up to a vacuum port.
Old Jun 27, 2010 | 04:12 PM
Twin_Turbo's Avatar
MAP = Manifold Absolute Pressure, the sensor sends out a voltage signal dependent on the absolute manifold pressure (manifold vacuum is actually pressure lower than atmospheric, hence absolute pressure)
Bellhousing bolts are fine, use grade 8 bolts
Old Jun 28, 2010 | 02:11 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
so hooking it up to another vaccume port is still alright? whats the best choice for that.
also if anyone happends to know that size of bolt it needs thatd be awsome so i can pick some up on the way home from work. thanks!
Old Jun 28, 2010 | 04:16 PM
Twin_Turbo's Avatar
Full manifold vac port, straight on the plenum and used solely for the MAP. No T-ed off connection.
3/8 UNC
Old Jun 28, 2010 | 09:26 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
these look like the right bolts?? ive never bolted a engine to a stand before and it just seems a lil sketchy.
Old Jun 28, 2010 | 10:17 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Grade 8 bolts have 6 marks on teh top of the head of hte bolt - Grade 8 are the strongest you can get unless you get specialty stuff (think ARP). Grade 8 is more than strong enough to hold up a block. Thats the size of the bolt that holds the transmission to the engine, so dont stress too much over it. Just make sure it's long enough to thread in a good ways and that they're the right size, but most importantly make sure it's Grade 8.
Grade 8 bolt:
From the picture of yours, they seem like they're Grade 5 (they have 3 marks instead of 6), they'd probably work, but I'd go get some nice Grade 8 bolts from the hardware store if it were me.
Old Oct 26, 2015 | 04:09 PM
thefogg's Avatar
did you ever find out if your MAP works fine/ hooking up a different vac port?
Old Oct 26, 2015 | 04:45 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
5 year old thread.....
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Elliswon
Aug 10, 2015 12:33 PM
