How DO i no if i need to run an EGR ? 350 swapped into the car
HI i am putting a 350 into my camaro and i am not sure if i need to run an EGR valve or not for the intake manifold ?
im in NJ and i want the car to be street legal, i have on a set of summit racing headers and a extreme energy comp cam ( 242-12)
this is my first v8 im doing and first project car, would i have a check engine light if im not running the EGR ? i am keeping the cat on it of course but i just don't want to deal with the EGR valve or the smog set up on the car.
i tried looking up some info on it but couldn't find any thing so any advice would help
thanks
thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How DO i no if i need to run an EGR ? 350 swapped into the car
Do you have to get an emissions inspection or just a safety inspection? Fastest best answer will come from your local inspections shop - ask them.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
It depends on the type of fuel delivery of the 350 engine and computer or lack thereof combination.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Always use EGR, because it does help mpg, and it does NOT hurt power.
Alright so ill get the EGR valve on it how would i set it up with headers?? i have a set of summit racing headers on the car now i dont have the old headers nor do i want to use them but the lines for the smog system were plugged up and cut off any ways
any help would be greatly apprechated, illl to check this thread more often
thanks for help
i do have emissions im in NJ,
thanks for help
On Probation
Engine: several
Transmission: none
Axle/Gears: none
EGR has Nothing to do with headers. Use an EGR-style intake manifold, bolt the valve to it, put a thermostatic vacuum switch in the thermostat housing, connect ported vacuum to that, then connect that to the EGR valve.
Car: 1986 IROC
Engine: 355" TPI
I used to live in Jersey. They are mainly looking for a cat and your emissions on the dyno. You will probably need a functioning EGR to pass. Are you planning on running a factory fuel system or an aftermarket carb?
theshackle
Mar 5, 2017 06:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
