What is this and do I need it?
Old Jun 29, 2010 | 01:35 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
As the title states, here are pictures. Posted a pic of the piece and my current setup to hopefully answer questions asked. The cable use to run to something off the CC carb we took off 3 years ago. Trying to clean up the engine bay a bit.
Attached Thumbnails What is this and do I need it?-sspx0082.jpg   What is this and do I need it?-sspx0083.jpg
Old Jun 29, 2010 | 01:40 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: What is this and do I need it?
it's just a cruise control vacuum diaphram. Take it off, seal the hoses so you don't have an open vacuum, and you'll be fine
Old Jun 29, 2010 | 01:41 PM
Twin_Turbo's Avatar
Yes, cruise servo.
Old Jun 29, 2010 | 01:55 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Alrighty. I noticed it ran into the firewall, should I plug it off there too?
Old Jun 29, 2010 | 02:34 PM
Twin_Turbo's Avatar
vac hose to brake pedal switch, you can simply remove that
