smoking like a steam engine out of breather hole! HELP please.
Old Jun 29, 2010 | 04:13 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
i just installed an 89 block with 70's heads, carburated. starts right up runs smooth but it puffs smoke out of the breather hole on the valve cover. when u hold the hole closed it comes out the dipstick tube. any ideas why its doing this? its so bad that it fills my 2 car garage up in about 30 seconds with smoke. its more white than blue and doesnt really smell like much a little like oil but not a strong oil or smokey smell. if its burning oil whys it coming out the valve cover?
Old Jun 29, 2010 | 04:18 PM
Twin_Turbo's Avatar
Re: smoking like a steam engine out of breather hole! HELP please.
Do you have a PCV hooked up? If not, do so.
Could be excessive blow by but we don't know the condition of the engine...fresh rebuild? a lot of miles on it?
Old Jun 29, 2010 | 04:35 PM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
I would have to say you have a blow by issue. Worn rings and scored cylinders.
Old Jun 29, 2010 | 05:20 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
it was rebuilt less than 5k ago in my tbi 88. i thought it was the valve seals it was burning oil really bad but blowing it out the exhaust so i put a pair of double hump heads on it and a carb into my 84 and now it blows smoke out the valve cover.
Old Jun 30, 2010 | 02:36 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
you never did answer the PVC question, it's kind of important to know before trouble shooting.
Old Jun 30, 2010 | 02:42 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Even without a PCV, that speaks of a serious issue: either water in the crankcase, or excessive blow-by. What does the oil look like on the dipstick?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lakeffect2
Aug 23, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
