which heads will allow reuse of stock zz4 intake / qjet
Old Jun 30, 2010 | 08:46 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
I have a zz4 and will be upgrading the heads/cam. I'm interested in either some AFR's or the GM Fast Burns. The cam I will go with is most likely the LT4 Hot Cam. I would like to either re-use the stock intake on this zz4 or need to know what intake I can run and still keep the computer controlled quadrajet. Also, very important, is keeping it under the stock hood. I know i've read it on here before but searched and searched and could not find it. I think i saw Five7kid comment on it a while back but cannot seem to find the thread. If it's the AFR's, any suggestion on which model to go with? Any help would be appreciated. Thank you
Old Jun 30, 2010 | 09:34 PM
Damon's Avatar
Re: which heads will allow reuse of stock zz4 intake / qjet
Fastburns are Vortec-style heads and will require an intake change. A set of AFRs with standard (85-down) intake bolt configuration would be able to reuse your ZZ4 intake (which is basically an Edlebrock Performer with GMPP stamped on it).
Old Jul 1, 2010 | 04:23 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I have a Vortec squarebore intake, a GMPP one, are you saying I should treat it as if it's an Edelbrock Performer intake? Or is it a performer RPM?
Old Jul 1, 2010 | 11:19 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
excellent. thank you for that
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
dutch930
Sep 11, 2015 06:58 AM
happyhapka
Aug 15, 2015 04:42 PM
TreDeClaw
Aug 14, 2015 06:58 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
