Power Steering Bracket pic request
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I took mine off years ago and kind of forgot where I put it can someone post up a pic of what it looks like, this is for 89+ serpentine belt setup. Looking for the part from the manifold and i guess to the back of the power steering reservoir, I see a stud there.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Power Steering Bracket pic request
I take it you want the pic for your 89 GTA with the 5.7L shown in your log on picture. I have a 5.0L but I dont know if the setup is the same.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
I tried to take pics but they are terrible. There wasn't enough room to position my camera in a way that shows much. Looks like the PS pump is held on by a verticle cast bracket mounted below the alternator. This shot is from the dr side front corner looking in. Sorry.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi, If you mean the one piece aluminum one on the driver side that holds the alternator on top and the PS pump on the bottom, I've got several pictures of one removed from the car. I'm apparently low-tech, but If you send me your email it would be much easier for me to send them to you than get them on here. Henry
Car: 89 GTA
Thanks guys, the big one piece aluminum I have just thought there was a small bracket from the back of the power steering reservoir where there is a stud to the header or something.
Is there anything bolted down with that stud?
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
