upgrading my engine
Old Jul 8, 2010 | 12:41 AM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
upgrading my engine
So I have a 305 in my 87 Camaro now. I found a 1970's 350 2 bolt main block and heads for sale locally for $200. What do you guys think? I've been reading around the net that 2 bolt 350's aren't worth building. I also don't know if $200 is a good deal or not. The block and heads have been professionally cleaned and prepared for a project the guy was going to do but he claims he chose to go in a different direction. Opinions?
Old Jul 8, 2010 | 12:51 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: upgrading my engine
Does it come with the rotating assembly?
See what the heads casting number is they may be boat anchors in waiting.
Old Jul 8, 2010 | 08:28 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
How much are you planing to build up the motor? A 2 bolt main, is fine if your staying under 500ish horsepower I believe. You can also upgrade the main bolts to hold up to 600 horsepower.
Old Jul 8, 2010 | 10:52 AM
Kwijybow's Avatar
Engine: Carb'd 305
I'm not really wanting too much horsepower. My Camaro is my daily driver so it has to remain streetable. I was aiming for 300-400hp. I'm more concerned with the price. Is a 2 bolt main 350 block and heads worth $200 CAD? Also, the guy told me that he is selling just the block and heads, no cam, no pistons etc.
Old Jul 8, 2010 | 12:13 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Around here I can get a complete motor from the junkyard for $100.
Old Jul 8, 2010 | 12:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I paid 100 for my block alone, but it had already been to the machine shop, dipped, with new cam bearings, and bored out. What are the head casting #'s?
Old Jul 8, 2010 | 12:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Does the block need to be bored? Either way, i'd say $200 is fair. I'd leave the heads on buddy's doorstop, and use your 305 heads. Chances are good that they are better anyway.
You'll need to buy a crank, pistons, etc. You'll be in $1000 when the smoke clears or thereabouts.
Everyone talks about a 4 bolt, but for a car, a 2 bolt is just fine. I have a 2 bolt, lots of people do.
Where are you in BC?
Old Jul 8, 2010 | 01:19 PM
Kwijybow's Avatar
Engine: Carb'd 305
I don't know what the head numbers are yet because I have been talking to the seller via email and he hasn't replied yet. I'm just wondering if going with a 2 bolt 350 is really worth it compared to building my 305. I'm in Victoria BC by the way.
Old Jul 8, 2010 | 01:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yes, a 2 bolt 350 is a 350. Consider it identical to a 4 bolt 350, the difference is so slim.
Don't bother building the 305 if you can get a 350 that cheap.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
