my engine is a turd
Old Jul 8, 2010 | 11:15 AM
volver's Avatar
my engine is a turd
-350
-engine had a miss
-cam lobe was gone
-replace broken performance cam with new stock 350 cam and lifters
-ignition timing set to 12 degrees
-followed edelbrock's idle setting procedure for 1404 carb
-engine stumbles over 1500 rpm in neutral. Engine stumbles over 2500 rpm in gear.
-at WOT gas vapor shoots out the top of the carb.
-Small puffs of smoke from exhaust that smell like raw gasoline at idle. Large clouds when punching it.
-Added a fuel regulator.
-Rebuild the carb
-got a tuning kit added the smallest jets and largest rods.( lean as possible)
-replaced distributor, cap and rotor, new plugs, new wires
-this brought the revs up before it stumbles by 500
What is my issue?
Old Jul 8, 2010 | 11:40 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: my engine is a turd
Using in-tank pump or mechanical pump with a pickup?
What's fuel pressure set at?
Have you tried changing timing up or down 2 degrees and see what happens?
Old Jul 8, 2010 | 12:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The carb isn't rich in it's settings, you can't physically tune a carb to get it to run that rich. Something is wrong. Not tuning.
I think it's more ignition then it is fuel.
- Pull your valve covers off while running. Make sure all rockers are a-rockin'
- Make sure each plug is firing. Hook up your timing light to each wire to verify.
- Pull your plugs and see if any look odd, like it's not firing. Then diagnose that hole.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
