tpi fuel pressure
Old Jul 10, 2010 | 07:25 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
tpi fuel pressure
I have a question I have tpi on my 91 camaro now and was wondering what fuel pressure I should start off with. I have a 383 with 24#lb injectiors also a aftermarket afpr and a mail tune order. I have read and read for days to fine a fuel pressure to start with but I read 37lbs all the way to 50lbs. any help would be apprecteid.......
Old Jul 10, 2010 | 09:01 PM
Smoothjr91z28's Avatar
Car: 91 Z28 CONVERTIBLE
Re: tpi fuel pressure
According to the dealers service manual for 5.0L & 5.7L with the ignition “ ON " and engine “ OFF " (zero vacuum), fuel pressure at the test conection should be (41-47 psi). I have it at 46 psi you can set it 50 psi. Also check this site https://www.thirdgen.org/optimal-fuel-pressure
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
