305 running rough
Old Jul 13, 2010 | 10:50 AM
rscamaro90's Avatar
Car: 90 camaro rs
305 running rough
got a stock 305 camaro today I was coming home and about 10 min from the house I was running about 50mph and it started running rough. Sounded like the catalytic converter. I got home and popped the hood and there was a little smoke coming from the passenger side firewall by the valve cover (no valve covers are not leaking). I checked all my plug wires on the dist. and they were on good. There is plenty of exhaust coming out of the tailpipes. If it doesn't seem like the cat what does it seem like. Thanks
Old Jul 13, 2010 | 10:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 running rough
If the cat was beginning to get plugged, you'd notice the engine running out of breath at ever lower rpm. If it happily pulled 4500 in first gear, the day before your trouble started, then it probably isn't the cat.
Old Jul 13, 2010 | 11:34 AM
rscamaro90's Avatar
Car: 90 camaro rs
I did not think it was the cat but wanted to make sure. Any idea on what else it could be? Still waiting on it to cool so I haven't checked the plug wires at the engine.
Old Jul 13, 2010 | 11:50 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
check vacuum lines as well - a vacuum leak can cause a rough running condition
Old Jul 13, 2010 | 11:56 AM
rscamaro90's Avatar
Car: 90 camaro rs
thanks, still waiting for it to cool but will check that along with the plug wires.
customblackbird
Aug 15, 2021 10:16 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
