Black canister leaking fuel?
Old Jul 13, 2010 | 04:44 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Today i got my fuel tank installed after changing the fuel pump and strainer, i got my lines hooked up and put gas in the tank and started letting the pump prime so i could get gas through my lines then started cranking my engine over, i started to smell gas so i checked the lines and no leaks there but when i got to the front of the engine bay, the Black canister on the driver side up near the headlights is leaking gas, so is there a solution to this or did i mess up my fuel lines? because i put new rubber lines in insted of the original lines since they werent there when i bought the car so any help is helpfull!!!!!!!!!!!!!!!!!
Old Jul 13, 2010 | 05:15 PM
firebirdland's Avatar
Car: 91 ,82 trans am 79 t/a
Re: Black canister leaking fuel?
same thing happened to me a few weeks ago after changing my fuel pump, except i could hear gas boiling in the canister too.
Old Jul 13, 2010 | 05:17 PM
Engine: L31 350
i didnt listen for gas boiling, did you get it to stop?
Old Jul 13, 2010 | 05:24 PM
ya, i unhooked all the lines and the plug on the canister, and i keep the gas cap loose. problem with it is, the gas fumes are strong when i shut the car off. . i didnt have any trouble with the canister until i had the fuel pump changed.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
