Fuel line broken
Old Jul 15, 2010 | 08:07 PM
Bluezero's Avatar
Fuel line broken
This might be a simple fix I don't know because it started raining but the metal line to the fuel filter from the gas tank pretty much snapped off. Easy fix? Will it unscrew from the tank and I can replace it? Thanks for any help.
Old Jul 15, 2010 | 09:45 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Fuel line broken
yeah you can buy a replacment line for it, or you can ghetto rig it up for now and just use a piece of rubber fuel line from your parts store and use 2 hose clamps on it for now, to get it off the tank youll have to drop your whole tank, along with your axle, and exhaust its definitely a fuuuuun time
Old Jul 16, 2010 | 12:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Make sure to get fuel injection hose, not standard fuel hose - standard fuel hose might not take the pressure of the fuel pump since it's for low psi carb applications. Fuel inj hose will say fuel injection on it.
Old Jul 16, 2010 | 02:54 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
correct, i forgot to mention that
Old Jul 16, 2010 | 03:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
AZ has the good Goodyear fuel injection rubber hose...........
Old Jul 17, 2010 | 12:35 AM
Bluezero's Avatar
Ok I fixed the fuel line but the car is giving me a 53 error code....or 35 lol. Anyways here's a video sorry about quality youtube wrecked it. http://www.youtube.com/watch?v=jLldnISO5SY. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
