will my lifters work
Old Jul 15, 2010 | 09:55 PM
camarokid144's Avatar
im going to swap a milder cam and springs into my motor comp cams says i should use #863-16 i have crane cams #11553-16 whats the diff in these lifters i know the complifters are retro fit and that part is not important they are both the same type of lifter i just dont understand are there milder lifters to go with milder cams are they all basicly the same
Old Jul 15, 2010 | 10:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: will my lifters work
Originally Posted by camarokid144
i know the comp lifters are retro fit
Are listed as regular flat tappet lifters
http://www.summitracing.com/parts/CCA-863-16/
Unless you put the wrong numbers up I am seeing the Comp lifters as flat tappet and the Crane as roller lifters.
Completely different types that don't interchange.
Not withstanding that the 11553-16 are listed as mech roller lifters which go on a different type of cam to a hyd roller cam
What cam are you going to install ?
Old Jul 15, 2010 | 10:55 PM
sorry wrong part # com#853-16 the cam i have is comp#12-415-8 springs comp#986-16p thanks
Old Jul 16, 2010 | 03:05 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The 853 lifters are retro fit for hyd roller cam ( right type for the cam you list )
but the Crane ones you say you have are for a solid roller cam.
Is that correct Crane part # ?
Do they look like this?
http://www.oreillyauto.com/site/c/de...325P&ppt=C0146
What cam ( solid or hyd roller ) do you have them on at present?
Old Jul 16, 2010 | 07:57 PM
yes the crane # is correct i got them in a pkg deal with a big *** hyd rooler cam and some heads with springs i gave comp my engine specs and they suggested those parts just wanted to know if i could save a few hundred bucks by using those lifters
THANKS FOR ALL YOUR TIME AND HELP
Jake_92RS
Jan 28, 2020 10:37 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
