power lag? ticking noise? hmm........ lets see
Old Jul 17, 2010 | 10:07 PM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
So,... i was at the shop today. One of my frnds was painting the sign on the wall outside for me. I gave him a lift home. starting kinda making wird noise like it wasnt breathing right,...... like it was kinda missing. Also seemed lik there was no power or it was very sluggish. SO!,..... i go back to the shop lock up and grab some tools so i can fix when i get back home. Pull driver valve cover cause that seems where the moise was coming from. And TADA! rocker stud snapped in half. rocker was just chilling there. So here is a pic of the polly lock nut with half the stud in it. figured i would make a thread bout this cause it might help someone down the road. I will show you how to get this stud out with out damaging the poly lock nut. here is a pic. Im gonna run to the shop and get this all sorted out i will post more pics in a lil bit.
Old Jul 17, 2010 | 10:25 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: power lag? ticking noise? hmm........ lets see
Ugh u mind checking out my post?, does my problem seem similar?...i have no noises at all tho.
Old Jul 18, 2010 | 01:33 AM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
so i will be taking my car to the shop tomorow gotta fix my ride befor i start on the other project. This is how you get a broken stud outta a stock head. take two nuts that have the same thread pattern. tighten one down then the other on top of it. the take a wrench and put it on the lower nut and wrench away. ill get pics tomorow to show how this works. stay tuned.
Old Jul 18, 2010 | 08:58 AM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
Here is a pic of how i set it up to loosen the rest of the stud out. Put a rocker arm nut down on it then a poly lock tightened it down on top of the rocker arm nut. the slid the 5/8 socket over the poly lock nut and loosened it out.
Here is the other one installed and then i was done. BOOM!
Hopefully this helps somone someday. Thanks and until next time PEACE!!
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Sep 4, 2015 07:57 AM
sailtexas186548
Aug 24, 2015 10:11 PM
redmaroz
Aug 16, 2015 11:40 PM
