quick question regarding trans am lights
last night the pop up lights didnt pop up, i tried turning the ***** to no avail. never had any previous trouble with lights, i dont even hear the motoring when button is pressed, does anyone know if where the headlight motor relay or fuse is. thanks
Re: quick question regarding trans am lights
[quote=TOM305T/A;4613212]last night the pop up lights didnt pop up, i tried turning the ***** to no avail. never had any previous trouble with lights, i dont even hear the motoring when button is pressed, does anyone know if where the headlight motor relay or fuse is. thanks[/quote
Did you ever figure out the light problem. Having the same problem if you got an answer I'd love to hear it.
still having problem, I checked fuses all are good, i need to see if there is a relay, i cant even turn ***** to bring up lights
Headlight control module is on the firewall next to the brake booster, looks like this:
http://www.top-downsolutions.com/pro...roducts_id=119
