Threw another dang rod
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Threw another dang rod
Yeah, it sucks not having a good lift. Im so spoiled with four Rotary lifts and a drive on 4 post.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
UPDATE GUYS!!!! This is gonna have everyone scratching their heads. At 8:35 PM today (Thursday), I went to my IROC to get my small Maglight to kill all the black widows under my apartment stairs. So I said o what the heck, Im gonna lube up the upper engine. So I cranked the engine and all I heard was the normal clicks of my Bosch III's firing away, the normal engine noise, and the roar of my 80 series Flowmaster muffler. But there was something different, there was no loud clicking or knocking!!!!!!!!!!!! I even went to the extent to rev the engine all the way and I mean I floored it and nothing but music to my ears. It sounds smooth. I turn the IROC on and off a couple times and its sounds good. I have no freakin idea what the heck is going on. I havent had any chance to pull the valve covers to check the valve lash. I cant believe that the noise is gone. ASE doc, has this ever happened in your mech experience. Any ideas what is going on guys?
ok. I fired her up agian today and now the knocking is back.
. Im gonna have to pull the damb valve covers and see if the damb lash is off. Ill post another update when I get the chance.
. Im gonna have to pull the damb valve covers and see if the damb lash is off. Ill post another update when I get the chance. Supreme Member
Car: 87 IROC Z28
Engine: 355 cid TPI
It seiter gonna be valve lash or the flexplate. Im really leaning toward the flexplate. This is exactly how a cracked flexplate behaves.
Cool bro. Its wierd. yesterday it was gone and now today its back. Gots me
and
and
Car: 1990 formula firebird T-top
Axle/Gears: thinking 2.73
just a question man but did you check the header or donut gaskets... that really is how that sounds to me
HAHAHAHAHAHA. Donut gaskets??? The last time I heard of donut gaskets was back in the early 90's in my moms 1980 Oldsmobile Cutlass. Do 3rd Gens really have donuts? Sorry bro. My IROC doesnt use donuts. And yes. I felt around for any puffs of exaust and nothing. Plus the sounds is diffenitely metal to metal or in that relation.
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Id say its the flex plate(They wont do it all the time especially if you shut it off when its on a small bind where its supposed to be)
Check it youll figure out its prolly what it is
Waiting on my buddy to get his friends dolly. I cant jack up the Camaro here at my apartments. Ill get busted. Plus the asphalf is very soft here. Thats my first on my check list though.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The frequency of the sound can tell you a lot about where its coming from. A timing light can give you a good frame of reference as to whether its in the rotating assembly/trans flex plate, or valve train. If the sound happens at the same rate as the timing light firings, its in the valvetrain. If its 2x faster than the timing light firings, its in the rotating assembly or trans.
Car: 88 Camaro SC
Engine: SFI'd 350
This is a possibility since the OP had his engine replaced. The bolts must be tightened to 30 ft-lbs, or they will back out, and let the trans hang at an angle, which destroys the front pump.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 87 IROC Z28
Engine: 355 cid TPI
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
GREAT info man thank you for that!
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well I havent done any testing or inspecting yet (flexplate, or valve lash) but I did take the IROC for a round trip of 25 miles to and from work today. There was no sound other than the clicks of my Bosch III's and the FlowMaster 80 series. Seems like the ticking has gone away by its self. I got some info to why the sound has seized (probable cause). I was told by a friend of mine on this board that I may of had a collapsed lift. Some how the lifters piston may of had gottin stuck due to a forieghn object and it affected the way the checkball controled oil flow. Now There is no more knocking/ticking.
Here is the link to a video that I took a few days ago http://www.youtube.com/watch?v=hJ0oaNL2ayw .
Here is the link to a video that I took a few days ago http://www.youtube.com/watch?v=hJ0oaNL2ayw . Member
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I am am not sure what to say here. It seems that you really didnt check anything. You never said if you checked the lash on the valves, or the flex plate. you just tried to pin point the noise and thats all that was said. Now you say the noise is gone, but for how long? So I dont understand what was going on. I saw the vids and it sounded to me like lifters. So whats the deal now? is it all better? I dont mean anything rude by this I just wanted to see what the deal was.
Nahh. I took no offense, although it seemed that way in the beginning. I couldnt do anything because its agianst the policy of my apartment complex to open up the hood to work on a car. Besides, here in the Imperial Valley, average temps here in the summer are around 110 *. So it too hot. I would go out and turn on the IROC just to keep the battery charged and thats when I found that the noise was gone. So no, I havent done anything to it. Im just waiting to reach my 3,000 miles so that I can drop in some 10w-30 synthetic and a additive for sticky valves just to be sure.
As a matter of fact, I raced a civic yesterday. It aint much but here it is....
http://www.youtube.com/watch?v=RERbW5HiEp8
I was gonna record a quick acceleration but a civic next to me challenged me so it was a last minute race.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Please dont insult me. I know a few cops who take drugs away from illegals right here in the valley for personal use. Not all cops are "perfect." So please Mr. Officer, lets get
and dont try to intimidate me.
and dont try to intimidate me. Thread Starter
You are a moderator here in the messageboard and I dont think JT would like it if you tried to insult or intimidate members. From what I last remembered, the board is to help other members, not intimidate.
Axle/Gears: Stock
Oh I get the heat thing, here in north Texas we hit 110 plus 60% humidity =130 no fun so I get it.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
1) Racing belongs in the racing forums
2) Street racing is illegal
My friendly suggestion to you would be to remove the video since it's self incriminating by nature, and to continue discussing your rod/lifter/whatever issue in this thread or maybe even talk about how you got a C4 transmission to bolt into a thirdgen.
-- Joe
If you want to come over and verify the tranny, by all means, come over to cali. I'm not a tranny type of guy. I bought a tranny, took the shops word for it and palo. Que mas quiero. By the way, there tons of thirdgen owners who make tons of illegal mods to their cars. Why you picking on me? Let's keep this thread what it is. I was trying to prove that my IROC now runs fine after I had a engine noise issue. Your comment "
I wish people around here would post videos like that. Would be a lot easier for a conviction when I arrest them for negligent operation" has nothing to do with the thread so stop harassing me.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
I don't know if that's true (cali crushing racing cars). Here in my county, if caught racing, license gets suspended, cited, and car gets impounded. From what I know, my video is incriminating on my behalf, but it doesn't give a cop the right to apprehend me. It is evidence which will only bring attention to me, but the police do sometimes get mad and speed even when there is no emergency. I'm not saying that I'm a angel, but everyone has broken the law at one point in their life. If anyone has a problem with the laws, talk to your congressman. I hear you. You claim not to harass me. But I did get offended. Now can we just let this whole mess rest?
Right. I'm not insulting anybody and:
-- Joe
-- Joe
anesthes, Do you wanna read more on 1987 Corvette trannies with 700R4's? Follow this link. http://www.corvettefever.com/howto/4686/index.html
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Back to topic maybe? How about we get that much closer to bringing another Thirdgen to life.
People post up videos of racing all the time. Heck half of Youtube is that. WHO CARES?
We all do it at some point, just don't have a video of it. He has a 40 second clip of all out and clearly no immediate danger to anyone. Get off his case man. Not saying it's okay in any way, but it just doesn't matter.
How's the car coming Chevy86 IROC-Z?
hydrolic144, thanks for supporting my view
. As for the condition of my IROC, I feel that I can stop worring about the engine now. I was worried about investing more money on a engine from Summit Racing but since the noise stopped, I can now put my worries to rest. I feel better now. I was gonna lose out on about 2 G's but now I can spend my money on other stuff such as weather stripping, another hatchglass/rear spoiler panel that supports the hatch spring loaded trunk cover. So such to list with so little money to spend.
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
uhmm the noise WILL come back as previously mentioned you NEED to check you flex plate ESPECIALLY before racing it ...you do realize many people have lost feet/legs from flexplate/flywheel failures the sound could be gone due to the flexplate is bound on itself i assure a sound like that just stopping does not meen problem fixed your car is wayy too nice to neglect the noise
im not trying to be a jerk or anything but you have got to check that out man
please keep us updated
Slowmaro87, I had no idea that there's been accidents of that nature. I will take your advice very serious and I will definetely check my flexplate. I appreciate your concern. You've earned a special respect from me. Thanks.
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
I wish people around here would post videos like that. Would be a lot easier for a conviction when I arrest them for negligent operation.
-- Joe
-- Joe
I just thought it was an interesting topic for discussion. Wasn't calling you a liar. Just was curious how you got it to bolt up.
I'm not harassing you. I pointed out a non direct suggestion. Most people would say "Ahh, maybe I should delete this now". I hear California crushes cars that belong to street racers. Do you really want videos of yourself on youtube??
-- Joe
YOUR A MOD ??? IN A TECH FORUM ??? SERIOUSLY ?? YOU OBVIOUSLY HAVE NO CLUE WHAT YOUR TALKING ABOUT....... THERE WAS NOTHING DIFFERENT ABOUT THE 700R4 THE VETTES GOT IN THOSE YEARS,OTHER THAN THE CALIBRATION AND TAIL.
HERE'S SOME FRIENDLY ADVICE......... LEAVE THE GUY ALONE.
NO ONE CARES IF YOUR A COP OR JESUS F-IN CHRIST.
YOU HAD TO PUT THAT OUT THERE HUH.....????
YOU DID NOT RADAR HIS CAR,YOU DONT KNOW HIS SPEED OR THE LIMIT ON THE ROAD,NO FACE,NO NAME,HECK I DONT EVEN SEE ANOTHER CAR.
ITS ALSO NONE OF YOUR BUSINESS WHERE HE LIVES
THIS IS A COMMUNITY,TO HELP OTHERS WITH THERE CARS, 3RD GENS,AND BY YOUR SIG YOU DONT EVEN OWN ONE.
YOUR OUT OF LINE
Car: 1988 iroc-z
you have a high volume pump??
i was told they can suck the pan dry during extended high revs
hows your oil level,pressure and condition during all of this ?
i have also cracked a flywheel because of loose bell housing bolts and heard the horror stories of when they let go at a high rev.it will come through the floor like a buzz saw.
for finding noise i use a long screw driver and put my ear to the handle side.
Ok fellow members. I appreciate the support but let's maintain our composure.
The mod may of had gotten out of line but I have already forgotten his comments. Like I said, I will inspect the flexplate. I think we should all chill and watch the Discovery channel. There is a show about the Trade Towers called " 9/11: After The Trade Towers Fell."
. - got a high. Volume pump. Come to think of it, my oil level was half a quart low just after I heard the noise. So I filled her up and little by little the sound went away.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I believe you just called me an idiot.
-- Joe
anesthes, enough is enough. Im gonna post a copy of my purchase of the 700R4. Now please note the phone number to Transplant Transmission. Call them and ask what is needed to be done when buying a tranny from them. As a matter of fact, ask for Rob. He will tell you that the core needs to be sent WITHOUT the tail-end housing. So Yes. It is what Rob tells me and yes I have a 87 Corvette with my original tail-end housing. So please anesthes, let it go. I do understand your point about the cbeam but as I began to remember what I did when I recieved the tranny, I remembered that I had to put in my original end housing (and I remember clearly because I had a hard time removing and installing the rear bearing of the housing). Now that I remembered and have cleared up the confusion, can we just get back to the topic?
Here is the tranny company that I bought from.... http://sitekreator.com/Trans-Plant/main_page.html
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I had a couple of C4 vette casings a while back, which I could not use in a fbody because it didn't have the cast boss. It took me forever in a day to get rid of them locally..
Hope you find the problem and hope it's minor.
-- Joe
Im glad we are communicating without butting heads. They just bolted right up. The studs where hard to line up but with a little bit of elbow grease and a couple of cramps later, it worked out. Well it time to eat. I hope that this has not caused any serious issues.
Car: 1988 iroc-z
you change the tailshaft.
i gave him advice on his car,you posted a borderline threat.
and on top, your a RAT.
Dear regal301,
You have received an infraction at Third Generation F-Body Message Boards.
Reason: Flame baiting/Provoking
Decided to attack on a discussion he was not a party to.
typical cop,got picked on in school,hates his job takes it out on other people.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
