what does this do?
Old Jul 23, 2010 | 11:06 AM
mikesta's Avatar
what does this do?
http://shop.advanceautoparts.com/web...AMS_1069561141___
i need to know exactly what this does and where it mounts up on a 305 tpi,
my car at idle it raises and drops rpm repeatedly,could this be the problem? ill try to get a video of exactly what its doing soon so you can all help me diagnose it
thanks
Old Jul 23, 2010 | 12:09 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: what does this do?
Not likely, sounds more like your Idle Air Control valve.I believe there is a tech article here somewhere on how to adjust it.
Old Sep 17, 2010 | 07:51 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
I know that Charcoal canister on my 87 is pouring fuel out of it. Looks like the purge valve takes in fuel line, and maybe working with a solenoid and canister suposed to restrict / take in fuel vapor?
But I just picked up the same part number, as trying to replace stuff with that so my car is drivable again, Can't find the canister to match my car/ line setup
Ive also had been having the rpm jumping issue on startup, and then car randomly dieng when driving. Ive checked/ replaced everything else. didnt now this part of the car existed till fuel started pouring out.
