Issues w/vacuum system, engine won't stay running
Old Jul 23, 2010 | 12:37 PM
sqfirebird's Avatar
Car: 1989 Pontiac Firebird
Engine: V8 305 TBI
Transmission: Automatic
I was driving the car down the road and the engine started to sputter then eventaully shut down. The engine will turn over but won't stay running, like it's running on 4 cylilders. The car is a 1989 standard firebird with an automatic v8 305 tbi. The code kicked out was 32, which says to check the egr valve and map/boro sensor. So far I have replaced the map sensor, egr valve, egr solenoid, pvc valve, air filter, oxygen sensor,iac and from a previous coolant issue, the engine temp sending unit, thermostat, and radiator fan switch. The car will stay running like normal for 10 seconds if I unplug the vacuum line going to the map sensor, but will shut down when the engine idles down. If I leave the vacuum line plugged into the map sensor, the engine will not stay running for any amount of time. I have checked the fuel pump, relay and fuel injectors, which all seem to be operating properly. The car is not a daily driver and has been sitting for 3 years until recently. I have owned the car for 15 years and have never had any major issues with it.
Any help/suggestions would be appreciated. So far anybody I have mentioned this too says they have never heard of this problem before????
Fast355
Dec 2, 2016 06:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
