Car Randomly Wont Start For ME
Old Jul 23, 2010 | 05:25 PM
SSZ2891's Avatar
Randomly i will go to start my 90 rs 305tbi and it wont start. Ill turn the key and absolutely nothing. Wont Make a sound. Everytime it does start however it takes like five seconds of turning over before it finally starts. What could it be.
Old Jul 23, 2010 | 06:06 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Car Randomly Wont Start For ME
You may have a worn out key or key in switch. This will cause your VATS to work erratically. You may want to invest in a VATS bypass module. They are available through various suppliers. I did a google search and found a bunch of options, one for $2.98
Old Jul 24, 2010 | 10:55 AM
SSZ2891's Avatar
its weird cuz if it happens ill usually just have to attach jumper cables to the battery and jump it for literallly 2 seconds and it starts right up every time. im thinking the battery doesnt have enough juice to turn the engine over. possibly a drain or something. thats what im thinking....?
Old Jul 24, 2010 | 09:04 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh. I misundersood the point of your thread. I thought that the car was randomly starting or not starting without intervention. Check your batt terminals and clean them as needed. Make sure that they tighten securely. They sometimes strip out. Have your battery tested. Most shops will test it for free.
Old Jul 26, 2010 | 01:38 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
When you say it does nothing does it have power or is the car completly dead? If its completly dead the first thing i'd check would be battery connection
Old Jul 27, 2010 | 09:15 AM
SSZ2891's Avatar
no the car is getting power but when turning the key i get nothing at all
Old Jul 27, 2010 | 09:41 AM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
I had a similar problem and it was a bad connection to my starter solenoid. Sometimes it would be getting power and other times it wasn't, all i had to do was tighten up the nut that had come loose
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
killer777
Aug 8, 2015 02:47 PM
Sherpajames
Aug 7, 2015 06:56 PM
