Car starts then dies...
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
Ok i just finished putting in new oil pan in the car...i take the car out for a spin works fine stop to get something to eat and then home.... i go to ride out again the same day at night time and the car didnt start. i thought i might needed to jump it but ill do it later.... the next day i try it again and it started fine but it died seconds later.. i have changed fuel filter and checked the vacuum hoses and they are all fine. i just don't know what can be wrong
i just dont know what can be wrong if it drove fine then nothing
i just dont know what can be wrong if it drove fine then nothing Thread Starter
Car: 92 Camaro RS
Engine: 3.1
Re: Car starts then dies...
well i figured it out i looked at everything again and i saw that one of my vacuum hose under the intake was melted... i luckily found it.
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
What is your fuel pressure?
Can you hear the pump prime? What I mean is, when you first turn the key on, can you hear the pump run for 2-3 seconds?
Transmission: 4L80E/4L80E
It would be best if you could get a fuel pressure gauge hooked up so you can report what's going on when you hear that hum. You may have a pump that is "running", but isn't putting out any pressure. Or, you may have a pump that runs when the ignition is turned on, but never runs after that.
One suspicious area is the oil pan. There is an oil pressure switch that is a back-up circuit for the fuel pump. If that circuit has been compromised (pinched, cut, loose, etc.), that could be your problem.
Car: 91 RS
Engine: 3.1l
My car had that same problem the past 4 weeks. I changed everything in the ignition system new fuel filter and vac hoses, If your car has good fuel pressure and the problem persists check your injectors with an ohm meter to see if the impedance is at an accepted value. 4 out of the 6 on mine wen't bad and did as you explained.
Car: 92 Camaro RS
Engine: 3.1
well i just changed the spark plugs and still nothing and i know my fuel pump stays with pressure solid 40psi . i am wondering mayb the fuel injectors clog or mayb no spark. i dunno i am getting frustrated with trail and error
Good move with the fuel pressure check. That's testing, not guessing.
Spark check is fairly easy.
Clogged injectors isn't too likely.
Car: 92 Camaro RS
Engine: 3.1
do I test the injectors and how do I get to them. But if it's not the injectors I am running short on ideas what it could be. Vats? Computer? Crimp wire and where can it be found?
Car: 91 RS
Engine: 3.1l
To be able to check all the injectors you are going to have to remove the plenum (the big silver part on top of the engine). Then once you do that you will see the fuel rail, on each side of the rail are three connectors that plug into each injector. Remove those connectors and with an ohm meter test to see if the injectors read between 11 to 14 ohms, and also if they are within .5 ohm variance over all six.
Car: 92 Camaro RS
Engine: 3.1
Thanks well here is the check list
Spark plugs **new
spark plug wire **new
Ignition coil **new
dizzy had s crimp wire soder and heat srink it
pelum has been remove and will check injectors tommrow to see if clog or no working.
fuel pressure test 40 psi and holds
any other checks/info/procedures would be great.. any input as well
Spark plugs **new
Ignition coil **new
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Were your plugs wet or dry? Did you check spark?
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Car: 92 Camaro RS
Engine: 3.1
I Did check for a spark and yea it works but when I took the old ones they were black and a bit wet. It's a 92 camaro 3.1 v6. How do u check/look for that MAF sensor. I am also thinking that it maybe out of timing now cuz I did have to take of the dizzy to fix a crip wire and snice I exchanged the spark wires I may have to that. Any ideas how to start that. Gonna research now but a pointer can help. All the input from everyone is helpful and I like shooting ideas out cuz it teachs me more
Engine: 5 Liter 305
Axle/Gears: 3.45
I think your car is MAP, not MAF. I could be wrong but all the V8 camaros from that year are and I have never owned or worked on a V6 third gen.
Car: 92 Camaro RS
Engine: 3.1
well here is some good/bad news... i have place the car in timing and i have spark again woot.. but the car doesn't wanna start. although it spudders when i put starter fluid in the intake so it kinda narrow my choices i think. unless someone else thinks otherwise. i am down to the a) injectors being dead or b) something controlling the injectors is bad... let the testing begin....
Car: 87 IROC Z28
Engine: 355 cid TPI
Check injector pulse using a test light or noid light. If you can get to one injector connector or find one of the two injector drive circuits in a connector outside the intake. I assume you have a good repair manual with thorough wiring diagrams.
Car: 92 Camaro RS
Engine: 3.1
well i check one of the injector and it read 5ohm. i dunno about the others yet but i am betting that they are all dead. so i am thinking about doing a swap. i hear that the injectors from a ford bronco 2/ranger 2.9 give my car better response.
Engine: 5 Liter 305
Axle/Gears: 3.45
I would just put some stockers back in that are tested to assure good matched flow. With the bronco injectors (or anything thats not LIKE stock) the ECM wont know how to keep it stoich unless theres a tune.
Car: 92 Camaro RS
Engine: 3.1
well it finally starts... it was the injectors.. after all testing injectors was the issue. test ohms where no more that 13. i parted out a firebird from its injectors and it started like there was no promble... i would like to thank everyone for there input and info...
Engine: 5 Liter 305
Axle/Gears: 3.45
That'll be $238.47 cash or credit? We dont accept checks from people with third gen camaro's!
db057
Aug 11, 2015 10:11 PM
