high rpm miss
Old Jul 25, 2010 | 06:34 PM
bbccamaro's Avatar
high rpm miss
I have a summit billit hei with there multi spark box, at around 5900-6000 rpms it has a bad miss. I have checked all plug wires, plugs and rev limiter setting. All seems fine, it starts great runs great up until the last 66 feet of the quarter then cuts out. Has this happened to anyone else? I'm sure like everything else I am moving out of the street parts into more race type parts. If I need a new set up, some recomendations would be appreciated.
Old Jul 25, 2010 | 08:27 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: high rpm miss
I'd suggest trying to borrow a better module for the HEI, and see if that helps.
Old Aug 1, 2010 | 08:19 PM
bbccamaro's Avatar
Re: high rpm miss
Found it!!!!!!!!!!!!!!!!! secondary fuel bowl float set a little to low. Thanks for the reply.
eightsixseven
Dec 16, 2024 01:50 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
jackhammer
Aug 15, 2015 10:04 PM
