Engine issues, bad fuel pump or injectors?
Old Jul 26, 2010 | 12:48 PM
bigwilly262's Avatar
Car: 1987 IROC-Z28
This has been a frustrating problem so far. The car is an 87 350 tpi generally stock except a PO put slightly larger injectors on it, 24s I think.
The problem is that sometimes the car will bog down when accelerating at low rpm. It sputters and goes nowhere, and adding more throttle makes the engine knock and run worse. After a little bit it will usually catch and then I have to keep the rpms above about 1700 or it will have problems regardless of what gear its in. The rest of the time the car runs great plenty of power and idles and sounds fine.
It has new spark plug wires, tps sensor and 02 sensor and I've popped in a second identical ecm and same problem. When it is messing up the 02 readings go to 4.44 mv and stay there the entire time it is missing, then goes back to normal readings.
The weirdest thing is the fuel pressure. There is a gauge mounted on the fuel rail. At normal idle it will go to about 43 psi, then fall down to about 40 after a second or two, then bounce between about 35 and 40 rapidly, like engine speed fast and repeat. At some throttle the pressure goes up and the gauge starts bouncing in a larger range centered in the 40s, at about engine speed. When it starts missing the gauge starts bouncing all the way from 50 to 0 and will do that the entire time its missing.
This makes me think that the problem is fuel related, but does this sound like injectors or the fuel pump? All injectors passed resistance testing 16.3-17 ohms.
Sorry for the long post, its been difficult problem to nail down so far. Any thoughts?
Old Jul 28, 2010 | 09:06 AM
Car: 1987 IROC-Z28
Re: Engine issues, bad fuel pump or injectors?
Could it be the fuel pressure regulator? Anyone?
Old Jul 28, 2010 | 11:28 AM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
would be my guess
Old Jul 28, 2010 | 06:18 PM
Car: 1987 IROC-Z28
Well I just changed the pressure regulator, no change. Fuel pressure still still oscillating like crazy, 0-50 when its missing
Old Aug 11, 2010 | 10:23 AM
Car: 1987 IROC-Z28
Well problem is fixed. Turns out I had a bad fuel pressure gauge and a bad pump. Changing the gauge showed me my fuel pressure was only getting up in the 20s. So after a minor battle the pump is changed and pressure is back up where it needs to be. Drives like a whole new car
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
