1986 trans am problem need help!!!
Old Jul 28, 2010 | 09:46 AM
jcola's Avatar
Hi I am new to this...My son and I purchesed a 1986 trans am, we did a tune-up on the car but the problem is after driving the car for a while it acts like it is out of gas and just stops. I will not start again for a while but usually will start up again if we put fresh gas in. We changed the fuel filter and in doing so the guys said that the filter had water in it. We are not sure how long the car sat for with the previous owner. I have been reading up on this issue and most suggest to go buy HEET and put that in to soak up the water. Does anyone have any other suggestions?? Please help my 17 year old son is very disappointed he can not drive the car because it always stops at some point during the drive.
Old Jul 28, 2010 | 10:10 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Re: 1986 trans am problem need help!!!
First thing I'd check is the fuel pump. Make sure you have good fuel pressure. If not.....could be a clogged or bad fuel pump.
Old Jul 28, 2010 | 10:20 AM
jcola's Avatar
Thanks we will probably change the fuel pump if all else fails meaning (HEET)....the guy that changed our fuel filter said he hears the fuel pump hum when we start the car.....the car does start and drive from point A to B and then dies with no warning.
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
