flex plate backwards?
Old Jul 28, 2010 | 11:11 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
i have a mini starter for a 168 tooth flywheel and i have a 168 tooth flex plate, i can crank it and it will work but once the motor had ran the starter drive gear almost always will hit the flex plate. i am wondering if my flex plate could be backwards or if there is something else that could be wrong. any help would be great at this point cause im sick of having to hand turn the motor just to start it again, thanks Ty.
Old Jul 28, 2010 | 11:41 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: flex plate backwards?
More likely you need to add a shim between the starter and the engine block.
Old Jul 29, 2010 | 12:15 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
EVERY starter has to be shimmed, and instructions for doing so are always included with starters, as well as the shims. Shims are also available at any auto parts store in the event you got a used starter that did not include them.
Old Jul 29, 2010 | 02:33 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
do you mean every aftermarket starter? cause my old starter was not shimmed and i used the wire that came with the shims and it fit perfect. but i will try shimming it tomorrow and see what happens, thanks
Old Jul 30, 2010 | 06:13 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
to the contrary, not all starters have to be shimmed, im running a mini starter on my 383 no shims, but also its not a cheap mini starter, however not all starters need shims............
Old Jul 30, 2010 | 07:13 PM
Stephen's Avatar
Car: 87 GTA
I've only had to shim 1 starter in my whole life.....
Old Jul 30, 2010 | 07:42 PM
Car: 1992 RS
Engine: Carbed 350
Guess I'm the lucky one that has had to always shim a starter - never had one I didn't have to shim!
Old Jul 31, 2010 | 01:03 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ive never taken one off and not found a shim and the ruels say, put back what you take off.
But some folks always have left over parts when they do a job
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
