Anyone with an improper cam install
Old Jul 29, 2010 | 12:54 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
A buddy put my engine together.
He put the cam in wrong. He lined up the wrong dot on the crank sprocket.
But before I found this problem, the intake valves were hitting the pistons, just the intake valves. I actually broke one valve in the combustion chamber.
Now I am really scared that the other valves might be bent.
Anyone have a similar situation?
Old Jul 29, 2010 | 01:01 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Anyone with an improper cam install
Saw a thread on here a while back where this happened to a 427, looked pretty nasty and the valves were barely kissing the top of the pistons.
Gotta remember that 10 camshaft degrees (ie, off by one tooth) is 20 crank degrees... No wonder it hits the top of the piston.
You don't really have a choice but to tear it down
Old Jul 29, 2010 | 08:04 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You probably didn't bend the exhaust valves, but the heads do have to be removed.
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
