engine block number?
Old Jul 30, 2010 | 11:05 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
hey guys
so i have a 92 rs camaro tbi. should be a 305 (auto) but its to strong to be a factory 305. looking at the motor you can tell its been rebuilt/swapped.
so since i had my intake off (replaceing the gaskets bc one of the po did a **** poor job putting it back on) i looked on the driver side...no numbers. so i looked at the passenger side and the number 14098821 was there(the block) however a google search turned up no such thing soooo how do i i.d. my motor to see if its a rebuilt 305 or a 350?
Old Jul 30, 2010 | 11:13 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: engine block number?
If the numbers were actully 14088551 not 14098821 then its a 305 2 bolt main.
Old Aug 2, 2010 | 02:34 PM
DARKmj16's Avatar
Engine: 305 tbi
i double checked after i couldnt find anythign the first time, the number is indeed 14098821
Old Aug 2, 2010 | 02:37 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
there was nothing behind the left bank ? it should ...being a 92 have a 5.0 or 5.7 stamped on the block ...theres also a tab on the front of the block on the right bank that has like date codes it should also tell you more info on the motor
Old Aug 2, 2010 | 02:41 PM
DARKmj16's Avatar
Engine: 305 tbi
ya all the chevy blocks ive seen/worked on always had a 5.0 or 5.7 stapped on it, which is why im puzzled and ya ik bout the right front tab...just dont want to get down there and look for it lol but looks like i might have to
Old Aug 2, 2010 | 04:52 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
ya i think its 87'up have the liter on back of block makes it much easier but there should be a number either way
Old Aug 5, 2010 | 01:35 PM
DARKmj16's Avatar
Engine: 305 tbi
hey puzzle. the heads and intake appear to be the 305 factory stuff (unconfirmed tho) but the block, on top of not haveing the 5.0 or 5.7 stamp, has a mechincal pump spot (with a plate over it) and get this, its on the passenger side! so ideas?
Old Aug 5, 2010 | 02:46 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Originally Posted by DARKmj16
hey guys
Are you sure you are looking in the right place? From what I researched in the past, most engine block numbers are on the right hand side (or driver side) behind the dist. near where the block meets the bell housing. Also I know you have already double checked the numbers but make sure you have a good light and all grease and dirt are cleaned away to be absolutely certain of the numbers.
Old Aug 7, 2010 | 01:51 PM
DARKmj16's Avatar
Engine: 305 tbi
yes im sure, thats where i pulled this number from, altho it was ont he passenger side. but it was still near the trans bellhousing on that lip fromt he block behind the dist.
Old Aug 7, 2010 | 06:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
On the '87+ engines ( 1 pce seal cranks ) the 5.0L / 5.7L is on drv side and the block casting # on pass side
Old Aug 7, 2010 | 11:05 PM
jamienoel's Avatar
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
This is the information I found:
It is a 1986-92 305 with a 2 bolt main.
Also listed:
305 86-88 Truck.
305 86-88 Malibu.
Last edited by jamienoel; Aug 8, 2010 at 04:13 AM. Reason: Because I'm forgetful in my old age.
Old Aug 7, 2010 | 11:29 PM
tricky1's Avatar
Car: 1982 Pontiac Trans Am
Engine: Chevy 350 Vortec Roller
Transmission: Turbo 350
Axle/Gears: Moser 4.11
I have a print out of the GM casting numbers from the old mortec site and it doesn't list that number. Unless you want a 305, look for this number. 10243880. That's the 350 vortec roller cam block that they also used to make the ZZ4 motors and if you're real lucky and find it in a c2500 pickup you may even get lucky and find a 4 bolt main motor.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
