need help with oil pressure sending unit connector .
Old Aug 2, 2010 | 02:34 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
in a nutshell i pretty much pulled the oil pressure switch and the electrical connector snappeoff fromthe wire , where can i find this connector? i tried tpiparts.net and they dont have it , autozone has many but none look like OE , i did this by accident , i couldnt get the connector off. ,i feel lame
Old Aug 2, 2010 | 10:12 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need help with oil pressure sending unit connector .
http://www.dormanproducts.com/flipbo...nductTite.html
On page 37 of that online catalog, you'll see the connector - part number 85180.
You should be able to go to Advance, Autozone, Oreilly's, whatever and have them order it for you. They will have to look it up in their paper catalogs, so talk to a manager not just the $8 an hour '***-ociate' behind the counter.
These are Dorman parts - all the parts stores carry Dorman parts, so whether or not they know it, they can special order Dorman parts.
Or, yank one at the local JY.
Old Aug 2, 2010 | 06:21 PM
nice little animated catalogue , that connector isnt the one for my oil pressure switch "rear of intake manifold " the connector on mine is a single tab , male tab on the pressure switch and a female plugg .
Old Aug 2, 2010 | 07:10 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What youre talking about is just a spade connector. Get one from your local parts store. They have them with a nylon jacket for insulation. Or did you save the rubber boot? You may be able put that back on the connector, if you get the connector without the nylon cover.
Old Aug 2, 2010 | 08:43 PM
true , true ,though the nylon boot is stuck on the spade connector along with the female input , should the boot come off easy or should it be a struggle , because its a srtuggle and wont come off.
Old Aug 2, 2010 | 08:44 PM
Just cut it off, crimp a new ¼" slide terminal on the wire, and move on.
Go to the parts store and look at a new one, and match it up with the terminals hanging in the Electrical aisle. You'll see it's a ¼" slide.
Not sure about "struggle"... never had that happen. All I know is what it IS, not how somebody else's ACTS.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
