Whats leaking?
Old Aug 4, 2010 | 08:22 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Whats leaking?
Can anyone identify this leaking oil part?
Not the oil filter obviously....
Old Aug 4, 2010 | 08:38 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Whats leaking?
That is your oil pressure switch for the gauge in the car. Either thats leaking or you have a leak higher up such as the valve cover or rear of the intake.
Old Aug 4, 2010 | 08:44 AM
Bungle's Avatar
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Re: Whats leaking?
Ah.. so that may explain why the oil pressure gauge starts off reading normal and the pressure dies away during a drive....
Old Aug 4, 2010 | 09:13 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Whats leaking?
agreed. time to get out the deep sockets
Old Aug 4, 2010 | 12:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Whats leaking?
You'll notice that the connector is a 3 wire job - make sure the parts store gives you another 3 wire unit - often their computer screens pull up the older 1 wire job instead.
Old Aug 4, 2010 | 12:49 PM
Benjam88's Avatar
Re: Whats leaking?
Had the same problem. My oil pressure reading dropped to zero, thought I killed my motor day after getting my car :P
Old Aug 4, 2010 | 10:15 PM
Bungle's Avatar
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Re: Whats leaking?
so could i get these at any decent parts store? I am out in the Middle East and would have to order it.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
