coolant leak
Old Aug 4, 2010 | 03:39 PM
firehawk1724's Avatar
coolant leak
whats up fellas... i have a coolant leak on my 89 trans am..i just changed hoses and radiator..those all checked out dry. also no noticeable leaks from the water pump so any idea of where coolant could possibly be leaking from? also the car never overheated at least not since i've had it(3weeks) and didnt have that leak i received it. thanks
Old Aug 5, 2010 | 04:30 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
Re: coolant leak
It could be leaking internally and either mixing with your oil or burning off in your combustion chamber, depending on where it may be leaking. Check your oil for water spots. If it is leaking into the combustion chamber, you will normally blow white smoke or smell a sweet smell out of the exhaust. Also, check the hose that connects the overflow container to the radiator. This could leak as well, causing a loss of alot of coolant over time. Finally, check that the radiator doesnt have a pinhole somwhere. Look for discoloration on the outside of fins/jacket.
Also, you may consider whehter it was just really low on fluid and needed a couple of fills to fill up all of the air pockets, or if it is truely leaking.
Old Aug 5, 2010 | 09:59 PM
Re: coolant leak
well there isnt any coolant in my oil or vice versa...i have no smoke coming out of my exhaust at all...so its a mystery..my hoses check out the rad is new and dry...any thoughts? thanks
Old Aug 6, 2010 | 08:51 AM
dv013003's Avatar
Engine: 5.7
Re: coolant leak
Check for wetness under the coolant overflow--there could be a crack in the bottom allowing coolant to seep out (it can be very hard to see). Also, check the lines above the oil filter. Some cars have plates above it that circulate coolant in that area to cool the oil. Follow the lines back and make sure the connections are not leaking and that the hard coolant lines along the body have not rusted through.
Old Aug 6, 2010 | 09:53 AM
Re: coolant leak
will do gonna check those in the 20 minutes...
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
