help with smog delete
Old Aug 4, 2010 | 08:59 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
When you take off the smog control do youhave to block anything off on the carb, or is it just remove everything and its all fine and dandy
Old Aug 4, 2010 | 10:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: help with smog delete
You have to block off the two pipes coming up off the manifolds, and the little pipe coming from the cat - here's the tech article: https://www.thirdgen.org/serpentine
You just have to ignore the part about the serpentine belt (I'm assuming you don't have because you are factory carbed).
Old Aug 5, 2010 | 11:56 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
actually im not factory carbed and plan on running hedman shorties and also have no cat just a straight pipe welded in which needs to be redone in the long run, so in that case theres nothing i really have to worry about correct?
Old Aug 5, 2010 | 12:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have to worry about the police if its a street driven vehicle in the United States. Its a violation of Federal Law to remove, disable, or tamper with emissions devices, including the AIR tubes, and the catalytic converter.
So, this is a race car for the track? right?
Old Aug 5, 2010 | 07:14 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
actually its a project dd, not a race car 305 doesnt make much power, it sat in the grass forever so i have an exhaust leak and im gonna take stock exhaust off and build one from scratch with shorties, and i beleieve the limit in mich i 54db or something, my dads freinds a cop so ill ask him
jaridjohn
Oct 5, 2015 07:01 AM
