Whats this engine worth?
Old Aug 6, 2010 | 12:31 PM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
So I recently changed out engines and have my old one laying around. What exactly is it worth if I were to sell it? I have a potential buyer but I don't know what to ask for it. The bottom end has roughly 10K on it, the top end about 1K. On the chassis dyno it made 224hp, 256ft lbs, with a 30lb flywheel, 11" clutch, T-5 and 3.73 gears. A 300hp mustang with intake and exhaust got on the dyno after me and made same hp and less torque. thanks guys.
Bolts
ARP 134-3610 – cylinder head bolts: Pro series
Mr Gasket 9824 – valve cover wing bolts: chrome; standard Y top; 1/4"-20 x 5/8”
Block
GM 5.7/350ci – 2 bolt main
One piece rear main seal
bored to 355
Cam Shaft
Engine Pro – timing set: double roller
Durabond – cam shaft bearings
Durabond – cam shaft bolts
Comp Cams Magnum solid cam & Comp Cams solid lifters CL12-223-4
Cam Style Mechanical flat tappet
Basic Operating RPM Range 2,000-6,000
Intake Duration at 050 inch Lift 236
Exhaust Duration at 050 inch Lift 236
Duration at 050 inch Lift 236 int./236 exh.
Advertised Intake Duration 282
Advertised Exhaust Duration 282
Advertised Duration 282 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.495 in.
Valve Lift with Factory Rocker Arm Ratio 0.495 int./0.495 exh. lift
Lobe Separation (degrees) 110
Intake Valve Lash 0.022 in.
Exhaust Valve Lash 0.022 in.
Grind Number CS 282S-10
Gaskets
Fel-pro 1205 – intake gasket set
Fel-pro QTCS45121 – timing cover gasket set
Mr gasket 3131g – head gaskets: 4.125” bore, 0.040” compressed thickness
Mr Gasket 5861 – valve cover gaskets: Ultra Seal; 5/16” thick
Power Seal – engine gasket set
Heads
Stock 1970 GM
Port, polished, 5 angle valve job, bench flow matched
64 cc milled to 60 cc
port matched to fel-pro 1205 intake gasket
Manley race-flo 11230 – valves: 1.94 intake
Manley race-flo 11521 – valves: 1.50 exhaust
K-Motion K-800 – valve springs: Dual, 1.460” Outside Diameter, 471 lbs./in. Rate, 1.085” Coil Bind Height; 180PSI seat pressure; seated at 130PSI
Harland Sharp – rocker arms: 1.5:1
Summit 7001SMT – chrome valve covers and timing chain cover
Intake Manifold
Wieand Stealth 8016
Port matched to fel-pro 1205 intake gasket
Rotating assembly
Silvolite 1470 – Pistons: 30 over bore 7.9:1 on 64cc heads cast aluminium
Power Seal – piston rings
Engine Pro – main bearings
Engine Pro – rod bearings
jhawkeye
May 25, 2022 06:33 PM
Streetstuff
Sep 7, 2015 09:23 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
355tpipickup
Aug 19, 2015 10:02 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
