code 43 and code 44
Old Aug 9, 2010 | 09:36 AM
jcola's Avatar
code 43 and code 44
Okay I was finally able to get the codes off my 86 trans am and it started with code 12 and the 43 and 44...I know the 12 in normal because of the engine not being on but the power is on...but what is code 43 and 44 and how do I fix it....please help I am a mom trying to help my 17 year old son get his car on the road and drivable before the summer ends.
Old Aug 9, 2010 | 11:03 AM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: code 43 and code 44
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
I would consider replacing the knock sensor (located in the engine block itself on the passanger side). If that has no effect I would also look into what is called the ESC module (electronic spark control module). From what I understand the ESC module reads knock counts from the knock sensor and pulls timing accordingly.
For the code 44 I would swap the oxygen sensor and try a new one. I had an '86 that spewed a code 44 for months before I found out it was just a vacuum leak.
Old Aug 9, 2010 | 11:29 AM
jcola's Avatar
would that cause my car to die while driving
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
