rounded off coolant sensor need help
Old Aug 10, 2010 | 11:21 AM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
hey so im doing the wiring part of the swap and tried to use a socket to get the coolant sensor off (the one on the side of block that takes a blue wire) and find out that the nut is already rounded off. I just want to know what the next best approach is. I tried vice grips for 10 minutes but it just kept slipping..
Old Aug 10, 2010 | 11:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: rounded off coolant sensor need help
Have you tried heat?
Old Aug 10, 2010 | 12:10 PM
Pocket's Avatar
Car: 91 Trans Am
Blue wire is knock sensor. Those are very prone to rounding off and have the added bonus of locktite on the threads
Get a big pair of channel locks to the outer case. It'll wreck the sensor, but you'll get it out. Never a good idea to reuse them anyways
Old Aug 10, 2010 | 12:11 PM
0pyders's Avatar
well i have a small torch but theres a whole bunch of wires there so Im worried about doing that, plus i already barely have enough room to get my hand there (from under the car) oh well I'll give it a try.
Old Aug 10, 2010 | 12:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What swap are you doing?
Old Aug 10, 2010 | 12:15 PM
0pyders's Avatar
Oh really? I thought it was for turning the fan on. is the wire for the fan the one on the thermo. housing?
Old Aug 10, 2010 | 12:23 PM
0pyders's Avatar
305 -->350
Old Aug 10, 2010 | 12:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Now is too late, but it's a lot easier to swap the sensors while the engine is out.
Old Aug 10, 2010 | 12:34 PM
0pyders's Avatar
lol thanks. yet again learning the hard way, hope it pays off sometime.
Old Aug 10, 2010 | 12:36 PM
0pyders's Avatar
can i run the engine with it disconnected for a couple minutes? I'm really just trying to get it running so i can feel secure that there is nothing wrong.
Old Aug 10, 2010 | 12:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, no problem.
Old Aug 10, 2010 | 04:45 PM
Pocket's Avatar
Car: 91 Trans Am
Neither the knock nor fans switch is required to run. Performance will be crappy with no knock because it's in limp mode
For future reference, knock uses a blue wire and is in the engine block just above the oil pan. Fan switch uses a green wire and is in the cyl head between #6&8 primaries. Connector body changed colors from white to black to gray over the years, often inside of years. Seems like they used whatever was in the bucket when the harness was built
Old Aug 15, 2010 | 12:50 PM
1991z285speed's Avatar
Car: 1991 z28 Camaro
Engine: 5.0 H.O. TPI
Transmission: Borger Warner T5
Axle/Gears: 3.07 gear ratio
Hey, I just put in a Fan switch for my 1991 camaro z28. It is a 195 degree on and 180 off fan switch. The part number is 60600 from summitracing website. My problem is I am experiencing issues such as the engine running poorly and it not idling right at all. After a bit of driving the engine seems gutless. I removed the old themostat sensor, which was located on the driver's side of the engine block to put this new one. It was a green wire that led up to the old thermostat switch. Any advice or 2 cents would be great guys. Thanks.
-Ted
Old Aug 15, 2010 | 12:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In the drivers side head is the gauge sender. It has nothing to do with the thermostat or the fans.
Old Aug 15, 2010 | 01:04 PM
Alright, so its going to be on the passenger side? That would throw off the gauge reading and the engine running. Your not going to believe this, but the direction specifically said that it was either between cylinders 1 & 3, or 6 & 8. Hey I really appreciate your advice. I'll reverse it as soon as I can and let you know. Very much appreciated, Apeiron.
Old Aug 15, 2010 | 01:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The fan switch is on the passenger side between 6 and 8.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
