yet another guy with fuel delivery issues...
Old Aug 11, 2010 | 10:10 PM
90HSR406's Avatar
Car: '90 RS, UH-60M
Engine: HSR'D 400
Transmission: TCI POS DONT BUY TCI!!!
Axle/Gears: Three2three
i need some insight on what im doing wrong or overlooking. i have a 90 rs with a hsr'd 400 in place of the 305 tbi. when i did the swap i put a walbro 255 lph fuel pump in it. after about 8 mos the engine started to miss, spit, and sputter with any change in throttle after about a half an hour of driving. i checked the pressure and it wouldnt go any higher than 30 psi. so i removed and capped the return line to eliminate the regulator. it still wouldnt make it above 30 psi. so i changed the pump and the filter. the new pump made 43 psi, for about 6 months this time. the same syptoms came back. so i replaced the pump and filter aaagain. and here it is 6 months and a deployment to afghanistan later with the exact same problem. what am i doing wrong? is there something the tpi fuel system has that the tbi doesnt?
Old Aug 12, 2010 | 08:37 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: yet another guy with fuel delivery issues...
You might try just replacing the filter.
Old Aug 12, 2010 | 11:11 AM
90HSR406's Avatar
Car: '90 RS, UH-60M
Engine: HSR'D 400
i'll try it. it cant hurt right? thanks
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
