Fuel delivery problem. please help!
Old Aug 12, 2010 | 09:00 AM
Rags91RS's Avatar
Car: 1991 Camaro RS
Engine: 5.0L 305 TBI (L03)
Transmission: TH-700R4
Ok, I have a '91 Camaro RS 305 TBI and in the morning it starts up and idles really low, and struggles to stay alive. At low rpm its lacking power and throttle response. At higher rpm, like downshifting on the freeway to pass a ford, it pulls pretty hard and feels normal. It seems the air-fuel ratio is bad but gets better the higher the rpm. Any ideas? I have replaced the Throttle Position Sensor because i was getting that code, but it didn't seem to help. I have to drive across Texas in a few days and I would like to have this fixed.
-Thanks
Old Aug 12, 2010 | 12:07 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Fuel delivery problem. please help!
check to TPS and IAC again, also check your fuel filter and the fuel pressure reg thats built into your tbi, it only takes like 10 mins to swap it, it sounds like its rich, mine behaved that way when i was running an open y pipe its got good high end power but in the mornings when its cold its a PITA and sluggish on normal roads
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
