Oil pressure switch problems
Old Aug 12, 2010 | 04:18 PM
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
Hello everyone, so I've been having problems threading in the oil switch to the block. I have two 1/8'' NPT thread size switches, but every time I try to thread either of them it just eats and destroys the threads on the switch. Any ideas as to why this would be happening?
Old Aug 12, 2010 | 09:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil pressure switch problems
where on the block are you trying to insert them?
Old Aug 12, 2010 | 09:05 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Well possibly either you are cross threading it, or it's the wrong thread period. Also, check to see that the threads on the block aren't messed up, you might have to get a thread chaser and use it to clean them up if they are messed up. Then it should go without issue.
Old Aug 12, 2010 | 10:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I wouldn't want to chase the threads at the top of an oil passage on an assembled engine.
Old Aug 12, 2010 | 11:42 PM
Car: 86' Firebird
well i just retapped the hole and was good to go. Thanks guys for the input though.
Old Aug 13, 2010 | 12:02 AM
Car: 1992 RS
Engine: Carbed 350
I'd do an oil/filter change pronto - the retapping will leave shavings in the oil.
Old Aug 13, 2010 | 02:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A change isn't going to do much, any debris is already trapped in the passages past the filter.
Old Aug 13, 2010 | 03:14 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Buy one of those magnets made to magnatize a screw driver or such and do that to the tap in a said situation, it will atleast gather most of the shavings.
could also reach into the hole with one of those small magnetic pick up tools for lost tools behind a bench.
should get 99.9% of anything.
Unless its rements of a brass plug or fitting that was in there.......
Old Aug 13, 2010 | 11:21 AM
Car: 1992 RS
Engine: Carbed 350
Just asking for my own curiosity...
Could one add something like Marvin's Mystery oil, thinning the oil base down, hoping to flush anything left through the system a bit easier (since it's thinner), and hope any contaminents get trapped in the filter?
I mean I know there's a chance that a larger piece could get lodged in a smaller cavity (like inside a lifter) - but it would be better than nothing right?
The magnetized screwdriver was a good thought.
Old Aug 13, 2010 | 11:32 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's nowhere you could flush something out from. The only exit out of the oil passages is through places like the bearing clearances which are only a couple thou wide, or the lifter piddle valves.
Old Aug 13, 2010 | 11:01 PM
Car: 86' Firebird
oh yeah i used a magnet after i did it all. plus some of the solution i used to make it tap easier (forgot the name right now. Brain dead after work!) made it stick to the tool. Pretty simple stuff. I'm not too worried about any debris.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
